Hi, i have been having issues with my heat not working. It is very weak (not hot) especially on fan speeds 3 and 4. I have replaced the thermostat, flushed the heater core, replaced the coolant with universal green coolant, not Dexcol. I have tested the 2 blend door actuators and they appear to be working when the knobs are turned or adjusted. Engine temperature gets up to almost 50%.
Both heater core hoses are hot, top more so than bottom.
at this point I am not sure what else I can try.
as far as the A/C is concerned i thought it was not very cool last year but have not tested it out this year. heat problem has been going on for about 2 years now.
Thanks
Thanks
Mar 20, 2020 at 11:42 PM
