Weak alternator
122,000 MILES • 3.8L
ALE
  • 12 POSTS
Hi, sometimes my wife's van starts okay, sometimes the starter clicks a lot before it starts and sometimes I have to use my Diehard booster to start it. Did a small test on where I used the power windows at night with the headlights on while the engine was running and the headlight dimmed. Also did the disconnecting battery terminals test to see if alternator was good. these were the only test I have done, but would like to know if all this could be a sign of a weak alternator? thanks
Jun 9, 2017 at 12:24 PM
HARRY P
  • 2,292 POSTS
Your alternator actually has little to do with starting the engine. If the battery has charge in it, then it should crank over. I would start with checking the battery cables on all ends and making sure that (1) there is no corrosion (usually a greenish white chalky looking gunk) at the connection points and (2) that said connection points are tight. If you can move the cables, then the connections are not tight enough. You might also replace the battery terminals if they have not already been replaced. If none of that solves the problem, then you will probably need to pull the starter and have it tested at the local auto parts place (should be free to test it). Let us know.
Jun 9, 2017 at 1:17 PM
HARRY P
  • 2,292 POSTS
Also could just be a weak battery, but I kind of doubt it. Still take it to the auto parts store and test it to rule it out before taking the starter out.
Jun 9, 2017 at 1:21 PM
