Engine will not stay running?
2003 INFINITI G35
200,000 MILES
NICOLE GARCIA
We replaced the cams. There was an interlock device on it and the previous owners removed it. What do I do because it turns over and will not stay on?
Feb 11, 2021 at 12:16 PM
When you say it turns over but will not stay running, do you mean it just cranks and does not actually start or it will run but shut off as soon as it starts?
The fact that the cams were replaced makes me think we have a timing issue. So if that is the case then we need to check the compression and find out if the valves are opening at the wrong time which would cause this to not start. Here is a guide that will help with this:
Also, here is a guide that will help with this issue in general if the compression checks out:
Let's start with this and go from there.
Feb 12, 2021 at 9:39 AM
