We put the key in the ignition and it will not turn at all
180,000 MILES • 3.8L • 4 CYL • 2WD • AUTOMATIC
DOUG MALONE
We just bought this vehicle and it started one time but since then we have tried for over a day and it is still locked up. Does it have anything to do with the anti theft mechanism?
Jul 1, 2018 at 1:41 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Sounds like you are having trouble with the ignition switch. Normally the key would be able to cycle even if there was a problem with the anti-theft (Pass Key) it is just after cycling the switch the vehicle would not start if it had anti-theft issues. I have attached a tutorial for you to view regarding the ignition switch. Hope this helps and let me know if you have any further questions.
Danny-
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Jul 1, 2018 at 8:19 PM
