WD40 On Belt
93,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
RUBEN CORTES
So my belts were squeaking and I had WD-40 and a Belt Spray. I went on YouTube and this guy said to use WD-40. I am new to this car thing and I used WD-40. I went online to double check and I am starting to see that everyone's saying that WD-40 is bad because it is a lubricant and I need friction in the bands. What do I do! ( I already applied WD-40 like a dummy. lol)
Nov 29, 2016 at 9:04 PM
HMAC300
  • 48,601 POSTS
all these people put all types of crap on you tube . belts are a wear item like brakes and batteries. recommended replacement is 60,000 miles unless California and belt and tension-er should be replaced because of the problem you are experiencing. make sure to try to clean the WD-40 off pulleys with choke cleaner or brake clean if you decide to replace belt. It dries quick.
Nov 29, 2016 at 11:25 PM
JOHNNY G.JR
  • 320 POSTS
WD40 is a solvent,removes rust etc. In time it will eat up those belts,do not use belt dressing,it's a joke,like HMAC300 said it's a wear item,nothing lasts foreever
Nov 30, 2016 at 6:17 AM
DOCHAGERTY
  • 9,606 POSTS
Belts squeak when they're glazed/old. Replacement is the cure
Dec 1, 2016 at 11:25 PM
