I have a leak coming from the water pump! How can I fix this? Thank you!
Jul 26, 2017 at 11:27 AM
HMAC300
✓Experienced Mechanic
if it leaks then it should be replaced. see pics for instructions, install is reverse of removal. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Images (Click to enlarge)
Jul 27, 2017 at 12:10 AM
NEWMOM
MEMBER
1 POST
Engine Cooling problem
1994 Nissan Pathfinder Automatic
I just got a quote from a mechanic that said $880.00 to replace a water pump that costs only 60 bucks. And a timing belt that I'm sure isn't too costly either. Everything says this is an easy fix if you have metric tools. Am I being ripped off?
Sep 24, 2020 at 4:00 AM
(Merged)
PRONISSAN
MEMBER
The dealer I work for charges approximately 650 dollars. This fee includes water pump, timing belt, both cam seals, crank seal, timing belt tensioner pulley, drive belts and coolant. This fee includes all genuine Nissan components not those cheap aftermarket ones.
The estimate you are getting is exaggerated grossly.
(Merged)
EARLGRISDALEJR
MEMBER
1 POST
Engine Mechanical problem
1992 Nissan Pathfinder 6 cyl Four Wheel Drive Automatic
just bought a nissan pathfinder front of engine was torn apart for new water pump iam waiting for new water pump but do not know how the assembly goes to put all back together and trying to find a diagram or something online free to show it belt locations and stuff
(Merged)
JDL
autozone .com has free auto repair info. You'll have to register your vehicle, it is free. After you register, you can type water pump into their parts search box, the next page in the right hand column, should be info for the water pump.
you can also click on repair info, there will be several links.
(Merged)
CHARLIECAC1
MEMBER
1 POST
I just replaced my radiator, but fluid is still leaking. The hoses seem to be fine. Could it be my water pump that is causing the problem?
(Merged)
SERVICE WRITER
Use additional lighting and mirrors if need be, there are a multitude of possiblilities, but you have to see where the coolant is coming out of. If you see but don't recognize the name of the leaking, part, post a pic and we can help. This may be as simple as a hose leak.
