Water pump replacement
102,424 MILES • 1.4L • 4 CYL • TURBO • AUTOMATIC
PETER76
  • 5 POSTS
Can you send a pic/copy of the tightening sequence for the water pump? That would be much appreciated.
Dec 30, 2020 at 5:18 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is a tutorial for you to view on how to replace a water pump:
https://www.2carpros.com/articles/water-pump-replacement
I've attached picture steps below on how to remove and replace the water pump for your car. As far as tightening sequence it just states to install and tighten in a cross sequence and torque to 71 lb in. Hope this helps and thanks for using 2CarPros. Happy Holidays.
Dec 30, 2020 at 6:59 AM
PETER76
  • 5 POSTS
Thanks bro. I really do appreciate. You all stay safe and healthy.
Dec 30, 2020 at 7:01 AM
DANNY L
  • 5,648 POSTS
You're welcome!
Just remember lb in is a smaller scale than ft lbs. Let us know if you have any further questions on this issue. Thanks again for using 2CarPros and we hope you will use or site again in the future. Happy Holidays.
Danny-
Dec 30, 2020 at 9:01 AM
