Water pump replacement
170,000 MILES • 2.8L • 6 CYL • 4WD • AUTOMATIC
MLONG98
  • 79 POSTS
When replacing a water pump, is there anything else i need to replace? I am only replacing it due to noises (similar to a rusty CV ). Also, it wouldn't let me specify exact model, s10 Tahoe Blazer.
Feb 7, 2019 at 8:00 AM
SCGRANTURISMO
  • 4,897 POSTS
You definitely want to replace the water pump gasket. It wouldn't hurt to inspect/replace any coolant hoses going to the water pump (if any), and the thermostat and thermostat gasket. Here are a couple of links to helpful guides for you to go through:
https://www.2carpros.com/articles/water-pump-replacement
Hope this helps.
Thanks,
Alex
2CarPros
Feb 7, 2019 at 9:06 AM
MLONG98
  • 79 POSTS
Cool so just what i assumed. I have done the thermostat and gasket already, i was going to just use gasket maker to save a few.
Feb 7, 2019 at 10:42 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Absolutely nothing wrong with that. I like to use the red hi temperature RTV, or permatex The Right Stuff, but any gasket maker should work.
Thanks again,
Alex
2CarPros
Feb 7, 2019 at 1:02 PM
