Water pump replacement
2004 BUICK LESABRE
200,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
ROSS DOUGAN GRANT
Replaced thermostat but when shut off, leaks from water pump.
Jun 28, 2018 at 6:46 PM
DANNY L
  • 5,648 POSTS
Hello I am Danny.
Water pumps are made with a drain hole in the bottom. Once the pump begins to show excessive wear coolant will leak through the inner seal and begin leaking through that drain hole. It is pretty common in high-mileage vehicles. I have attached step-by-step instructions for you if you choose to do the repair yourself. Be sure that after removing the old pump that all surfaces are clean to promote a good seal for the gaskets and installation of the new pump. The long bolts are to be torqued to 22 FT LBS and the short bolts to 11 FT LBS. Hope this helps! let me know if you have an questions!
Danny
Jun 28, 2018 at 9:41 PM
  • 55,399 POSTS
This guide will give you a step by step while you use the diagram Danny gave you.
https://www.2carpros.com/articles/water-pump-replacement
Cheers, Ken
Jun 29, 2018 at 3:56 AM
