With my car listed above base model, I'm at a loss to explain why I have two water pump failures in three'years.
Yes, I'm on my third water pump, after the original unexpectedly quit with no warning; three years later a second water pump quit. The second failed pump was found to be the cause of an overheating condition. I had a trusted mechanic do the first repair, I myself did the second repair.
I just can't reasonably explain why this happened to myself, much less to anyone else. Is there any reasonable explanation?
Aug 26, 2019 at 1:31 PM
