yes it has a tensioner see picture, the list you see at bottom is the order you do to remove the tensioner you should also replace your belt as well as they are recommended replacement of belt and tensioner at 60,000 miles. picture two is of belt tensioner for other belt which you may as well replace both so you wont have to do again.
Images (Click to enlarge)
Oct 10, 2016 at 2:33 AM
