Water pump and timing?
1993 DODGE STEALTH
100,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
MOSES GRIFFITH
What happened after water pump change? If belts aren’t tight what happens? Will the car start?
Jul 12, 2023 at 9:53 AM
  • 110,240 POSTS
What belt are you referring to? If it is the timing belt, certainly if it isn't timed properly or tight, it won't start. Actually, if this is a DOHC or 24-valve engine, you will cause internal damage if the timing isn't correct.
If it is a SOHC, there are no interference concerns. I attached a pic below of a SOHC engine. Is that how you had the timing marks aligned?
See pic below.
Jul 13, 2023 at 5:31 AM
MOSES GRIFFITH
Thanks just fixed the timing in my 93 dodge stealth es.
Jul 28, 2023 at 5:00 PM
  • 110,240 POSTS
Thanks for the update. I love those cars. LOL I always wanted one, but no such luck.
Enjoy it and feel free to come back anytime in the future. You are always welcome.
Jul 29, 2023 at 1:20 PM
