Water pump and other
2012 FORD FIESTA
138,000 MILES • 1.4L • 2WD • MANUAL
PETER MUFC COLLETT
  • 6 POSTS
Had water pump changed, changed all belts and valves. Now it will not pull you out of bed. What could be the problem? Also had crank shaft pulley done.
Nov 1, 2018 at 12:20 AM
  • 110,244 POSTS
The water pump on this vehicle is driven by the timing belt. If engine timing was not properly done after replacement, that would cause a loss of power.
Next, you mentioned valves. Was the cylinder head removed to repair the cylinder head valves?
Nov 1, 2018 at 11:16 AM
