water pump
100,000 MILES • 1.1L • 4 CYL • 2WD • MANUAL
SOLOMILLZ1990
I need help with replaceing the water pump in my 1992 honda accord and step by step instructions on what needs to be done and how to do it
Jan 16, 2016 at 5:04 PM
WRENCHTECH
  • 20,760 POSTS
The water pump is driven by the timing belt which makes this a very involved and risky job to learn on. If a mistake is made with the timing belt it will cost you an engine because it will bend the valves. If you are determined to do this I suggest you subscribe to a factory information service link Alldata DIY. The procedures would be far too involved to post here.
Jan 16, 2016 at 10:18 PM
