Do I need to replace the entire water pump if the bearings are damaged or is it possible to just replace the bearings?
81,000 MILES • 2WD
MCAL012
Water pump.
Jun 4, 2023 at 2:42 PM
  • 110,248 POSTS
The bearing is non-serviceable. They are sealed inside the pump. When they fail, the pump needs to be replaced as a unit.
I attached the directions below for you.
Jun 4, 2023 at 4:41 PM
