How to test the water pump to see if it is working?
16,786 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
ANDRIN ATEM
  • 415 POSTS
Hi, please can I know how to verify if the water pump works or not, a procedure to check and test if the pump works well.
Thanks!
Jun 10, 2024 at 6:54 PM
  • 55,859 POSTS
You can remove the pump to inspect the water pump impeller. Here is how to remove the water pump so you can check out the internal workings of the pump. I would say to remove the radiator cap to check for the flow but if the impeller is partially missing it will still show flow but not enough. Check out the images (below). Please upload pictures or videos in your response to any problems so we can see what to help you with.
Jun 11, 2024 at 3:34 AM
