Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Avenger
Engine Cooling
Water Pump
Replace/Remove
Water pump replacement
1996 DODGE AVENGER
115,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
STERLING EMERY
MEMBER
Can I replace the water pump without removing harmonic balancer? Very limited on tools and resources.
Jun 11, 2019 at 9:55 PM
Experienced Mechanic
Good morning,
No, you cannot. The front cover has to be removed to access the pump and the cover is behind the balancer.
It would be highly recommended to replace the bet since you are at that point. You need to release the belt to remove it.
https://www.2carpros.com/articles/water-pump-replacement
Images (Click to enlarge)
Jun 11, 2019 at 10:18 PM
STERLING EMERY
MEMBER
Okay, thanks. the balancer has been very difficult to remove the bolt is on pretty tight even with an impact it doesn't want to break free.
Jun 11, 2019 at 10:28 PM
Yep. They are supposed to be very tight.
Spray it down with some lube and keep working with it.
Jun 11, 2019 at 10:35 PM
STERLING EMERY
MEMBER
Okay, thanks. I appreciate the help and advice.
Jun 11, 2019 at 10:40 PM
You are welcome.
Always glad to help.
Jun 11, 2019 at 10:55 PM
This video shows how to remove a harmonic balancer:
https://youtu.be/NZIMNkLxCMA
Jun 12, 2019 at 5:34 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
