Water pump replacement
138,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
FLIPPA334
  • 42 POSTS
I would like to know what is the best brand water pump to install on my car.
Nov 26, 2018 at 7:30 PM
Good morning,
I attached the brands from rockauto for you to view. All the brands I listed are good as long as they are new, not re-manufactured.
Do not use the Cardone pump. That is not new.
Removal and Installation
1. Drain the cooling system.
2. Loosen the coolant pump pulley bolts.
3. Remove the accessory drive belt.
4. Remove the bolts and the coolant pump pulley.
5. Remove the bolts and the coolant pump.
^ Discard the O-ring seal.
6. CAUTION: Do not rotate the coolant pump housing once installed in the engine. Damage to the O-ring seal can occur, causing the coolant pump to leak.
NOTE: Install a new O-ring seal and lubricate with the clean engine coolant.
To install, reverse the removal procedure.
7. Fill and bleed the cooling system.
Nov 26, 2018 at 8:40 PM
FLIPPA334
  • 42 POSTS
I did not get the list of the brands.
Nov 26, 2018 at 9:39 PM
It is in the first attachment I sent you. I just opened it up and the pumps and brands are there.
Motorcraft would be my first choice.
Nov 26, 2018 at 9:44 PM
FLIPPA334
  • 42 POSTS
A short water pump or long?
Nov 29, 2018 at 3:43 AM
Short.
Nov 29, 2018 at 3:46 AM
FLIPPA334
  • 42 POSTS
Thanks!
Nov 29, 2018 at 4:21 AM
You are welcome.
Always glad to help.
Nov 29, 2018 at 4:24 AM
FLIPPA334
  • 42 POSTS
The pulley at the top on the engine is squeaking. What is the official name for that particular pulley so I can replace it?
Nov 29, 2018 at 9:22 AM
Can you post a picture of the pulley?
Nov 29, 2018 at 9:25 AM
FLIPPA334
  • 42 POSTS
This is the one I am referring to.
Nov 29, 2018 at 9:38 AM
That is called an idler pulley.
Nov 29, 2018 at 9:59 AM
FLIPPA334
  • 42 POSTS
Is it the drive belt idler pulley?
Nov 29, 2018 at 10:02 AM
Yes it is.
Nov 29, 2018 at 10:07 AM
FLIPPA334
  • 42 POSTS
Okay, thanks.
Nov 29, 2018 at 10:10 AM
FLIPPA334
  • 42 POSTS
What is the difference between a 225/50/17 and a 225/50R/17?
Nov 29, 2018 at 12:08 PM
We are going off track from your original issue.
Please close this question and start a new question as you did with this question. Then we will be glad to assist.
Nov 29, 2018 at 8:53 PM
FLIPPA334
  • 42 POSTS
What causes the ABS light to come on on my crown victoria
Dec 12, 2018 at 1:55 AM
Hi there,
The site requests that since this is another area that you start a new question.
Go to www.2carpros.com/questions.
Thank you,
Dec 12, 2018 at 2:20 AM
