Water pump clutch fan removal
2001 FORD E-SERIES VAN
206,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
COLEMAN, MAN
I need to remove the clutch fan, but it seems more off a complicated job then I expected. but I will tackle it, just need a how to from the pros.. thank you.
Jun 6, 2020 at 5:40 AM
Good afternoon,
I attached a YouTube video for you of the procedure for changing the pump. It is a good video for all the steps needed for the replacement.
Make sure you replace the thermostat as well. Then flush the system and add new coolant.
https://www.youtube.com/watch?v=DiwC7Mn0EGY
https://www.youtube.com/watch?v=-Gzxo3u-SeQ
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
https://www.2carpros.com/articles/fan-clutch-removal
Jun 6, 2020 at 6:03 AM
