MEDIC68
water pump is leaking after i stop driving temp is at 200 when driving how long can i drive it before pump goes completely out. i check coolant level before driving each time add if necessary.i use my car for work delivery driver. how long does it take to replace the water pump?
Thank you
May 10, 2013 at 2:00 AM
HMAC300
  • 48,601 POSTS
a leaky water pump is like pulling the pin on a hand grenade and wondering when it will go off. So the answer is can't tell ya. what engine is it to replace a 4 or 6?prices vary around u.s.so check locally.
May 10, 2013 at 2:38 AM
