Water on floor
169,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
ZEELAFISK1
Got in my car tonight. It has been raining all day. Floor on passenger side is soaked and mat had water standing on it. Can see water dripping from the middle, top of floor board running onto the carpet. What can be causing this?
Jan 11, 2019 at 6:55 PM
Good morning,
The first suspect is the windshield. Over time, the seal around the windshield starts to fail and rain water can leak into the car from the are of leaking
The outside air vent. that is another point of leaking. It is under the grille by the wipers. The sealer rots away over time and then the water starts to leak into the car.
You are going to need to get under the dash and try to pin point the exact area of failure. It may mean you going to a self serve car wash and have someone blast the front windshield with high pressure water while you are under the dash looking for the leak point.
Jan 11, 2019 at 10:20 PM
