water mixing with oil engine
118 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
PERFECTOR CHISHALA
water is entering in the oil engine.
Apr 7, 2017 at 3:43 AM
CJ MEDEVAC
  • 11,000 POSTS
Sounds like a compromised head gasket.
A cooling system pressure test will probably confirm it.
Some parts store will "rent" you the tool to do it, "rent" really meaning "Deposit", in which you get all of your money back when you return the tool. So really, you use it for free.
The Medic
Apr 7, 2017 at 11:46 AM
  • 55,694 POSTS
Here are a couple of guide that will help you get the job done.
and
https://www.2carpros.com/articles/radiator-pressure-test
Best, Ken
Apr 10, 2017 at 4:48 AM
