Water mixing with Oil
120,000 MILES • V6 • 2WD • AUTOMATIC
IKHAGHU
My car overheated and the mechanic discovers that the gasket and two piston heads are bad which I replaced.
After assembling the engine back,it tested okay with still much whitish fumes from the exhaust which the mechanic assured me will cease with time.
I just discovered that the engine does not start properly and also oil still mixes with the water.
What should I do next?
Apr 14, 2019 at 3:32 AM
SCGRANTURISMO
  • 4,897 POSTS
I would take it back to the mechanic where the head gaskets were done. I would have him do a compression test. He should have to make it right. I have included a few links down below for you to go to:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
These are tests you can do yourself if you are worried that the mechanic is trying to pull the wool over your eyes. I would go back to him and see if he will make it right first.
Thanks,
Alex
2CarPros
Apr 14, 2019 at 6:12 AM
