WATER MIXING WITH OIL
2013 ALL OTHER MAKES ALL OTHER MODELS
95,000 MILES • 6 CYL • TURBO • MANUAL
GODYKE
The vehicle is Sinotruck Howo truck, when the engine is hot, the vehicle starts normally but when the engine is cold, it will not start unless the engine is forcefully turned manually before it will start. However, after the engine was started, it was eventually noticed that the engine oil is mixed with water, after changing the cylinder head gasket, engine oil and oil filter, it is still mixing oil and water. I do not know how and from where the water is mixing with engine oil.
Feb 29, 2016 at 7:40 PM
JOHNNYT73
  • 924 POSTS
It could still be the head gasket or the head or engine block has a crack in it. Did you have the cylinder head(s) sent to a machine shop to check for cracks and resurfacing?
Feb 29, 2016 at 10:29 PM
GODYKE
I want to send the engine block and cylinder head[s] to machine shop for examination / resurfacing. Thank you immensely for your wonderful advice.
Feb 29, 2016 at 11:24 PM
