Water leaking on ground
87,470 MILES • 3.3L • AUTOMATIC
COUCHSPUD
It is leaking water onto the ground where I park. I fill up the reservoir and a couple days later it leaks out. it does not seem like it's overheating but the temperature gauge goes crazy.
Dec 29, 2020 at 4:10 AM
Good evening,
You need to do a pressure test of the system to determine the source of the leak.
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/car-is-leaking-coolant
Once you find the leak, let me know and I can help with the repair.
Dec 29, 2020 at 9:24 AM
