Water leaking between transmission and engine?
220,000 MILES • 4.2L • 6 CYL • 2WD
LEE7862
Water leaking between transmission and engine.
Apr 13, 2025 at 8:26 AM
  • 55,676 POSTS
We will need more information to help you, when you say water do you mean coolant? If so, there are freeze plugs at the rear of the engine block that can get old and spring a leak.
This guide and video can help you confirm the leak:
https://www.2carpros.com/articles/car-is-leaking-coolant
How to install freeze plugs.
https://www.youtube.com/watch?v=2Qf7LT3LAX8
Please upload pictures or videos in your response.
Apr 14, 2025 at 4:46 AM
