Water leak coming from under A/C compressor
180,645 MILES • 6 CYL • 4WD • AUTOMATIC
BRIANHANKLA
It is not the water pump,or hose what could it be?
Apr 7, 2020 at 5:06 PM
Good morning,
You need to pressure test the cooling system to pin point the source of the leak.
https://www.2carpros.com/articles/radiator-pressure-test
Around that area is the intake manifold gasket. That is common for leaking where it meets the head. It is a thin aluminum gasket that corrodes over the years.
https://www.2carpros.com/articles/replace-intake-manifold-gasket
I would start with a pressure test. You can rent a tester or have a parts store do it for you for free.
Apr 7, 2020 at 9:08 PM
