Water leaking
125,000 MILES • 2.3L • 4 CYL • 4WD • AUTOMATIC
JCA10
I have water leaking into my truck. The entire insulation in the backseat and and front seat of the driver side is soaked. Any ideas of where the water is coming in at?
Feb 27, 2016 at 3:38 AM
HMAC300
  • 48,601 POSTS
check for loose seals around door especially if vehicle has been in a wreck. also for missing body plugs.
Feb 27, 2016 at 5:16 AM
JCA10
The car hasn't been wrecked I found that water was leaking through the back window and maybe the 3rd back taillight. Any idea of how to deal up the window
Feb 27, 2016 at 8:12 AM
HMAC300
  • 48,601 POSTS
if the back stoplight come s put some rtv under it then reinstall it. for back window se if seal is broken anywhere if not try putting rtv under seal as well. let the excess rtv dry like a day or so then cut off with a knife.
Feb 27, 2016 at 11:48 PM
