Water Leak After Rain in Front Passenger Floorboard
125,000 MILES • 4 CYL • TURBO • FWD • MANUAL
MEMPHISCUTEY
I have water to accumulate in the passenger side front floorboard after a heavy rain. I do have a sunroof but, I have checked the drains and cleared those (had that problem last year). I'm not sure where the water is coming in from since the area that I was getting the water into the car from the sunroof drain issue is bone dry. If it's not raining outside, it dries up after a couple of days with me sopping the water up with a shop vac and towels. The water is not discolored and doesn't smell like anti-freeze. Any ideas on how to fix this would be greatly appreciated.
Jun 26, 2014 at 1:53 AM
HMAC300
  • 48,601 POSTS
your heater drain may be plugged. we dont' have a good pic of that so check under the car in the area's I've pointed to it may even be off of firewall. use like a piece of caot hanger you won't hit anything.
Jun 26, 2014 at 2:40 AM
MEMPHISCUTEY
Thanks! I shall check that out when I get home from work.
Jun 26, 2014 at 4:07 AM
HMAC300
  • 48,601 POSTS
your welcome
Jun 26, 2014 at 4:59 AM
