Water leak
200,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
LEWIS.FANCHER129
Replaced radiator and thermostat still seeing water leaking.
Oct 2, 2017 at 9:39 AM
  • 31,937 POSTS
You will have to get a cooling system pressure test done, this will help locate any external leaks. if you can see the leak can you trace it back to its source. it may be a hose or a gasket leaking. if you cannot see it you may have to get a mechanic to get it up on a hoist to inspect from underneath.
Oct 2, 2017 at 7:56 PM
