water leak
2008 CHEVROLET
77,000 MILES • 4 CYL • FWD • MANUAL
JILL STEWART
Car is not overheating, but water is leaking out driver side front when I park. some water and the fan is on. no coolant, just straight water, but quite a bit if it. still fairly cool here in Iowa. I have not ran the AC.
Mar 6, 2017 at 1:05 AM
HMAC300
  • 48,601 POSTS
have a mechanic pressure check coolant system and see if there is drain plug missing on that side might be accumulating then draining out when you stop.
Mar 6, 2017 at 3:57 AM
