Water leak Water thoroughly soaked and pooled at rear floor
2003 BUICK CENTURY
73,000 MILES • V6 • AUTOMATIC
PHOENIX2016
Water thoroughly soaked and pooled at rear floor on both passenger and driver side after two months sitting outdoors. I flushed the air conditioning hose, inspected seals on doors and windows which seems to be good. After drying the floors and driving in summer, it was dry for a while but now, there seems to be a small damp spot under the rear passenger seat, approximately a hands length in front door. Underneath The rear driver side seat is dry. FYI, We did change the window regulator on rear window behind driver seat. Any idea on cause of leak?
Sep 17, 2016 at 6:15 AM
SATURNTECH9
  • 30,869 POSTS
If this is water and your AC drain is not clogged up then you going to have to water test your car. While looking for leaks are not fun.
Sep 17, 2016 at 8:15 AM
