Water leaking inside my car
100,000 MILES
LOU20
  • 88 POSTS
I have water leaking inside my car on the passenger side. it's coming from under the glove box.
May 28, 2020 at 8:36 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
That sounds like you heater core located in the HVAC box is leaking.Here is a tutorial showing how to replace a heater core:
https://www.2carpros.com/articles/replace-heater-core
I've attached picture steps below on how to remove the HVAC box in your car. Hope this helps and thanks for using 2CarPros.
May 28, 2020 at 10:27 AM
LOU20
  • 88 POSTS
Is the heater core expensive to get fix?
May 28, 2020 at 1:08 PM
DANNY L
  • 5,648 POSTS
Hello again.
Heater cores are a common part to be replaced due to leakage. The shop book calls for 4 hours of labor.Depending on your area most shop labor rates are around $100.00 an hour. Dealerships like Kia while charge more for parts and labor. Kia dealer part is $278.00 as opposed to AutoZone auto parts stores that want $100.00. It just really depends to what kind of shop you take it to.Hope this helps and thanks again for using 2CarPros.
Danny-
May 28, 2020 at 1:27 PM
