Can moisture or water in gas cause a rough idle or a low knock to trigger a knock sensor?
70,000 MILES • TURBO • 2WD • MANUAL
BHAMDOC1973
  • 2,007 POSTS
Water in gas?
May 19, 2024 at 11:09 PM
  • 110,245 POSTS
If you suspect there is water in the fuel, it can cause a few different things. For example, it can cause a rough idle, a misfire, power loss, stalling, hard starting, and will likely damage the fuel pump/system if not taken care of.
As far as the knock sensor is concerned, it can cause a problem if the engine's combustion is off. In other words, the air/fuel mixture is not where it needs to be. That can be caused by moisture. When the air-fuel mixture in the combustion chamber doesn't ignite properly or combusts unevenly, it can create pressure waves that cause a knocking sound. This knocking is recognized by the knock sensor which adjusts ignition timing to eliminate the knock.
If you suspect there is water, I recommend purchasing a fuel additive from a local parts store that is designed to eliminate moisture in the fuel tank. The one that I know of is called "Heet". See pic below.
Let me know if that takes care of the issue or if I can help in any way.
See pic below.
May 20, 2024 at 12:00 PM
