water getting into the carburetor from the reed valves
52,000 MILES • 2.0L • 4 CYL • RWD • MANUAL
2MAZDA4ME
My mazda b2000 have water inside the air assembly that's coming from the reed valves what causes this to happen pickup goes into high idles when cold start
Mar 14, 2014 at 10:53 AM
KHLOW2008
  • 41,812 POSTS
Most probably you have a faulty gasket under the carburetor. Engine is supposed to increase in rpm during cold starts but if it does not come down or takes forever to come down, there is a fault with the mechanism or vacuum controlling the fast idle system.
Mar 15, 2014 at 7:17 PM
