behind the idler pulley and below the alternator there is a leak
165,000 MILES
TOBY IE RUSSELL
I have a leak behind the idler pulley and below the alternator. I changed the water pump no leaks around it. Please help. in the picture you can see the last of the drip. It pours out from there.
Jan 9, 2017 at 6:29 AM
STEVE W.
  • 15,418 POSTS
Hard to tell for sure, could be the thermostat housing or a hose leak. Check the engine oil for coolant to make sure it isn't a timing cover leak.
Jan 9, 2017 at 7:22 AM
TOBY IE RUSSELL
The oil is great, no water at all
Jan 9, 2017 at 7:23 AM
  • 55,746 POSTS
Hey Toby,
Can you give us a better shot of the leak maybe from under the car? Its tough to tell is it more oil or more coolant?
Best, Ken
Jan 14, 2017 at 1:43 PM
STEVE W.
  • 15,418 POSTS
I think the stuff that looks like oil is really copper based bars-leak. I know there is a core plug in the hole I marked but it looks like the leak might be above that.
Jan 14, 2017 at 2:08 PM
