Water cooling system sabotage
207,310 MILES
LINDA THOMAS2
There seems to be a hose missing from the side of the reservoir and another reservoir under it not being used as it attaches to nothing.
Anyway I believe some one is trying to make it overheat.
Dec 19, 2020 at 5:33 AM
LINDA THOMAS2
This is what it looks like:
Dec 19, 2020 at 5:48 AM
I am not sure someone is trying to make this overheat as this reservoir should just have a small line running from the radiator cap opening to the overflow bottle.
Take a look at the diagram attached below and it shows where this line comes from. Sounds like someone just ran the line to some other tank for some reason. Did you just buy this vehicle?
Also, is the vehicle actually overheating?
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
https://www.2carpros.com/articles/engine-overheating-or-running-hot
If so we need to figure out why by taking a look at the guides above.
Let us know what questions you have. Thanks
Dec 20, 2020 at 6:04 AM
