Water coolant leaking
230,000 MILES • 2.4L • 4 CYL • 2WD
LAMENDOLA
  • 5 POSTS
I have the car listed above it's leaking coolant in front of the engine on the driver's side. It doesn't leak when car is off only when it runs for a bit then it starts dripping. It's in front underneath where the shroud is at. Can this be a hose and it's running down and leaking in front? Can you please help?
Jan 28, 2020 at 4:51 AM
Good afternoon,
Can you upload a picture of where the leak is located?
https://www.2carpros.com/articles/car-is-leaking-coolant
You will need to pressure test the system to determine the source of the leak.
https://www.2carpros.com/articles/radiator-pressure-test
Jan 28, 2020 at 5:24 AM
LAMENDOLA
  • 5 POSTS
It's leaking under the front side underneath driver side by the radiator next to the shroud I guess or it could be some where else and running down.
Jan 28, 2020 at 5:40 AM
I read that before but I need to see what you see. It could be leaking from many places. I am trying to narrow the area for you. I need some pictures to help you.
Can you do a pressure test? You can rent one at a parts store.
Jan 28, 2020 at 5:46 AM
LAMENDOLA
  • 5 POSTS
I'm at work as of right now. But I will take a few pictures for you. Thank you.
Jan 28, 2020 at 5:48 AM
LAMENDOLA
  • 5 POSTS
Jan 28, 2020 at 5:58 AM
You are welcome.
We will be standing by for the pictures.
Jan 28, 2020 at 6:00 AM
LAMENDOLA
  • 5 POSTS
How do you send pictures? Who do I send them to. Do you have a email I can send them to? Thanks.
Jan 28, 2020 at 6:11 AM
You can attach the pictures to this post and they will show up.
If they do not let me know.
Jan 28, 2020 at 6:31 AM
