After replacing the fuel filter.The watering code keeps flashing and it is not coming off.
Apr 3, 2019 at 10:54 AM
SCGRANTURISMO
✓Experienced Mechanic
Did you erase the code with your code reader after you fixed the problem? Another way to clear the code, although we can't really recommend it, is to take the negative battery terminal off the battery for five minutes. This will erase your vehicle's Keep Alive Memory (KAM).
