Water accumulation in fuel filter code keeps flashing
40,000 MILES • 3.0L • 4 CYL • 4WD
SUNIL SINANAN
After replacing the fuel filter.The watering code keeps flashing and it is not coming off.
Apr 3, 2019 at 10:54 AM
SCGRANTURISMO
  • 4,897 POSTS
Did you erase the code with your code reader after you fixed the problem? Another way to clear the code, although we can't really recommend it, is to take the negative battery terminal off the battery for five minutes. This will erase your vehicle's Keep Alive Memory (KAM).
Thanks,
Alex
2CarPros
Apr 3, 2019 at 8:02 PM
