Brown foamy water in the radiator
199,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
FEMA68
radiator water loss and brown color with foam. any problem with the head? thanks
Mar 18, 2017 at 5:52 PM
HMAC300
  • 48,601 POSTS
pressure check for leaks. this can either be the transmission cooler leaking into radiator or a head gasket problem/intake. auto parts sometimes rent these make sure system is full prior to testing.
Mar 19, 2017 at 1:50 AM
