Water leaking
117,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
ALICE JOHN
I have water turning out from under but it is not the water pump. seems to be mainly on the passenger side.
Oct 5, 2019 at 10:15 PM
CJ MEDEVAC
  • 11,000 POSTS
Are you having to refill your radiator/coolant reservoir because it is constantly getting low?
Maybe on a happier note, could this be a dripping air conditioner drain (which is normal with the A/C or defrost modes being used)
So like does it stop dripping when the heat and A/C is all in the off positions?
The Medic
Oct 6, 2019 at 6:40 AM
