little bit of water seeps out the overflow on first start in the morning
30,000 MILES • 2.2L • 4 CYL • 2WD
SMOKEESDAD
  • 7 POSTS
When I start my truck in the morning to idle and warm up a little, just a little bit of water seeps out the overflow. it only does this when it's first started, and sometimes not at all. Would i have a thermostat sticking because once the truck is warmed up no more seeping?
Jan 29, 2020 at 10:26 PM
  • 55,721 POSTS
This sounds like the beginning of the blown head gasket. does the truck loose coolant? If so here is a guide to help confirm the issue:
Jan 30, 2020 at 2:30 AM
SMOKEESDAD
  • 7 POSTS
no it does not lose any coolant when running, only the little bit when i first start it.
Jan 30, 2020 at 8:01 PM
  • 55,721 POSTS
Okay, it sounds like the radiator cap is bad. I would replace it and see if it still happens. Please let me know.
Feb 1, 2020 at 2:12 AM
SMOKEESDAD
  • 7 POSTS
already done that.
Feb 1, 2020 at 8:36 PM
  • 55,721 POSTS
When the coolant is seeping out can you try to squeeze the top radiator hose to see if the cooling system is pressurized?
Feb 3, 2020 at 2:37 AM
