Washer wiper problem
2005 KIA CERATO
84,597 MILES • 1.6L • 4 CYL • 2WD • MANUAL
TERRENCE COLE
Hi Steve my name is Terry, my washers wipers won't work at all, there is no noise coming through whatsoever. wipers are working perfectly fine. any idea? thanks
Jul 14, 2020 at 7:11 AM
4DRTOM
  • CERTIFIED EXPERT
  • 467 POSTS
There is not much in that ckt. I would start with making sure your washer pump fuse is good.
Below is a link showing how to check your fuses.
Let us know if that helps, if not we can dig further.
Tom
Jul 14, 2020 at 10:10 AM
STEVE W.
  • CERTIFIED EXPERT
  • 15,118 POSTS
The description sounds like either the washer motor or switch has an issue. Testing the circuit isn't difficult, the motor is mounted to the washer bottle and has two wires, black goes to ground and green is the power feed. If you apply battery voltage to the two connections on the wiper motor and it spins fine then you need to check for power and ground at the connector. To do that a simple test light connected to a ground and touched to the green wire should light up when you use the washer switch. If it does then the switch and power are good. Now connect the test light to the battery positive and then touch the black wires pin in the connector. If the ground is good it should light. No light would be a bad ground. Those can be as easy as the wire broke or rust at the screw that secures it.
Jul 14, 2020 at 10:26 AM
4DRTOM
  • CERTIFIED EXPERT
  • 467 POSTS
Hi Terrence,
How did you make out today? Did the fuses check out? Were you able to use the info in the articles to get you farther along.
Let us know how you made out.
Thanks,
Tom
Jul 14, 2020 at 10:28 PM
