Washer pump replacement
86,000 MILES
JOE STOKES
I went to fit a new washer pump as mine stopped working. But removing the clear tubing that goes too the rear jet the wrong end came off with the connector to connect to the other pipe. Where is the other pipe so I can connect them again?
Mar 28, 2019 at 7:07 AM
JOETECHPRO
  • 705 POSTS
Hey JOE STOKES,
I do not have the information for your vehicle here.
If you drop into a Renault dealer they will have parts diagrams which will show the entire hose and where the connectors are for the rear washer system. You should be able to get the answer you need from this.
Sorry i could not get you the information you need.
Best of luck finding it and getting it back together.
Regards, Joe
Mar 29, 2019 at 9:58 AM
