was stalling and hard to start now just won't start
150,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
PAPACURT
we changed the battery, fuel pump, fuel filter, cam sensor, crankshaft positioner sensor, coil pack and checked all fuses under the dash and under the hood all good
the fuel gauge show to be empty but the tank is full it was working when I parked it any ideas?
Feb 8, 2015 at 11:55 PM
HMAC300
  • 48,601 POSTS
check the asd relay under hood as well as fuses, then scan for codes. try wiggling crank sensor connector may be bad and also reset security system if no manual look online.
Feb 9, 2015 at 2:31 AM
