Was running fine now will not even start or turn over
125,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
WILLIEDYNAMITE11
  • 37 POSTS
Cars been running fine showing no signs of running badly etc.went out to start it and won't even click to turn over, won't turn over at all, but lights and radio work.
Oct 11, 2019 at 3:12 AM
Good afternoon,
I would start by testing the battery. You may have a low battery.
I would also check the charging system to be sure the battery is being maintained.
Oct 11, 2019 at 5:14 AM
WILLIEDYNAMITE11
  • 37 POSTS
I have both are optimum.
Oct 11, 2019 at 5:31 AM
What are the voltages?
Oct 11, 2019 at 5:33 AM
WILLIEDYNAMITE11
  • 37 POSTS
12.4.
Oct 11, 2019 at 5:50 AM
Okay, does the starter crank the engine over?
If not, then check for power to the little wire on the starter solenoid. It should have voltage with the key in the start position.
Oct 11, 2019 at 6:11 AM
WILLIEDYNAMITE11
  • 37 POSTS
Sorry for the delay I'm at work. it does not it doesn't even click it does nothing.
Oct 11, 2019 at 6:46 AM
WILLIEDYNAMITE11
  • 37 POSTS
I will check the small wire going to the starter.
Oct 11, 2019 at 6:47 AM
Keep me updated.
Oct 11, 2019 at 7:00 AM
WILLIEDYNAMITE11
  • 37 POSTS
Will do. thank you for your input.
Oct 11, 2019 at 12:30 PM
You are welcome.
Oct 11, 2019 at 5:21 PM
