All service lights on, but nothing seems to wrong with the car
168,000 MILES • V6 • 2WD • AUTOMATIC
BEN CLARK
Car runs great every things fine, all fluid levels fine.. Been this way for the last 50,000 miles. just plain weird.
Apr 17, 2020 at 8:21 AM
Can you clarify which specific lights are on? I attached a number of guides that we need to do in order to pull the codes. This needs to be the first step at this point so we can see what may be causing the lights to come on.
Let me know what codes you have and we can go from there. Thanks
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Apr 17, 2020 at 8:49 AM
  • 55,770 POSTS
I have seen this before it happens when the cluster goes bad. here is a video of the repair being done on a similar car with instructions in the diagrams below to show you on your car:
https://youtu.be/_HEC44xENxw
Please let us know what happens, check the images below.
Apr 17, 2020 at 10:53 AM
