Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Fusion
Interior
Instrument Cluster
Gauges
Speedometer
Not Working
Speedometer stopped working and multiple warning lights turned on
2006 FORD FUSION
70,000 MILES • 1.6L • MANUAL
STEWART MACDONALD
MEMBER
1 POST
A cluster of warning lights have come on ABS, engine light, brake warning light. Also, speedometer has stopped working .
Jul 6, 2020 at 7:05 PM
Experienced Mechanic
Good morning,
There are fault codes stored for the lights on the dash. The ABS system is most likely the reason for the all the lights.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
You can go to a parts store and have them read the codes. At that pint, let me know the codes and I can help narrow the area of failure for you.
The speedometer not working is most likely the issue. There is a sensor for this but the code will confirm this for us.
Image (Click to enlarge)
Jul 6, 2020 at 9:43 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
