warning lights
160,000 MILES • 2WD • AUTOMATIC
FARR2007
  • 244 POSTS
when car is off a security light blinks it is a red car with a key in the middle.now i am told many things cause this; steering lock, low battery in fob. honestly I have no idea. please help.
Dec 9, 2017 at 2:03 PM
WRENCHTECH
  • 20,758 POSTS
The security light is blinking because it is not accepting the transponder in the key you are using. If you have another key, I would try that first. Otherwise you are going to need the dealer scan tool to diagnose the issue and probably do some programming of new keys.
Dec 10, 2017 at 2:58 AM
FARR2007
  • 244 POSTS
It is push button start no key. there is a key to unlock doors.
Dec 10, 2017 at 5:09 AM
WRENCHTECH
  • 20,758 POSTS
You still have an electronic key that has to be within range.
Dec 10, 2017 at 5:11 AM
FARR2007
  • 244 POSTS
Mom leaves key in car all the time.
Dec 10, 2017 at 5:17 AM
WRENCHTECH
  • 20,758 POSTS
There may be an issue with using up the battery in the fob by leaving it in the car.
Dec 10, 2017 at 5:22 AM
